| | | Forums66 Topics128,264 Posts1,058,357 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 51 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Sep 2006 Posts: 51 | I have a few minor parts that I'm not sure if I want to be chrome or painted.
I painted them first, semi gloss black, such as the rest of the truck.
I decided to "brush paint" a couple of things today with some Chrome paine, just to see how it would look.
At a distance, it looks okay. Up close, the brush stokes are apparent.
I'll decided what to do when I put the parts back on the truck.
~ davey 1967 Chevrolet 1/2-Ton PickupIn the Stovebolt GalleryI'm not sure if I was ever as good as I thought I was, but I know I'm not as good as I used to be.I've forgotten more than I ever knew. Okay, where did I put it? A man can never have enough tools
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | You may want to try the spray version. I sprayed ti inside of my front turn signal assemblies with good results. I have a can here if you're in the neighborhood.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Hey guys, I'm not sure where to get it, but a guy once gave me a can of "Alumicote" which is supposed to be a spray aluminum used in the restoration of aircraft. I'm sure it is a little more expensive, but it is awesome and quite shiny and very durable.
Definately go with spray whatever you use as a brush should be left to houses! | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | I've picked up a can or two from the local parts stores and it is a mess to work with...or at least for me. Shake it until you can't hold your arm up anymore and then spray it VERY LIGHTLY. To make it look good do about 3 coats of paint. If you do more than barely spray it you will have a mess. | | |
