1 members (mick53), 202 guests, and 1 robot.
Topics128,115
Posts1,056,288
Members48,439
#1222763 06/26/2017 2:52 PM
Hello Fellas,
How difficult is it to remove the fuel pump on a 1955 235? The reason I ask is that I need to replace the metal fuel pump to carb line and It looks like it would be a WHOLE lot easier if I screw it on the pump then install the pump back on the engine.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
You don't have to remove the fuel pump to replace the metal fuel line.
If you remove the fuel pump you might have to put in a new fuel pump gasket.
So you're better off not removing the fuel pump.
Just make sure you don't cross the threads when screwing on the metal fuel line.
When you start to thread on the pipe fitting nut into the fuel pump port, and it starts turning hard, that will tell you the threads are crossed.
The pipe fitting nut should turn fairly easy until it bottoms out.
You may have to bend the pipe slightly to get the pipe fitting nut threads to line up with the fuel pump port threads.
Thank you for helping me not create more work for myself!
I'd recommend attaching the fuel line to the pump before the carb end. Keep it loose until you attach the carb end. Once you have both ends connected, them tighten them.
1959 3100 Apache Fleetside
Thanks Cablesmill.
