| | | Forums66 Topics128,034 Posts1,055,544 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | 1958 fuel gauge.... How does one test the gauge itself? Thanks | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I've seen a post on here that describes testing the entire circuit by manually raising and lowering the float and watching to see it the gauge move correctly. Other than that guess you can check it with an ohm meter to see that the circuit is complete. The first indicator for me is if the needle is in the home position just below the empty mark. Other broken gauges I've had the needle is way off. Best of luck and I'm sure others will be along with better info! | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Read your other post on this question but your punctuation was such that I couldn't upstand what you were asking. Take sender wire off back of gauge. Use a piece of wire (I prefer alligator leads). Ground the gauge sender post, turn ignition switch to run. Needle will go empty or full. Turn ignition switch off. Remove wire from sender post. Leave all wires off sender post. Turn ignition switch to run. Needle will move to other end of gauge. That checks gauge for operation. Check back in if you need further help. Good luck.
| | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Thank you beltfed I'll give that a try. Just want to make sure gauge is working before installing. Sorry for my punctuation errors , I am visually imp are in a way that computer screens cause me visual problems | | |
