| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Hello Fellas,
How difficult is it to remove the fuel pump on a 1955 235? The reason I ask is that I need to replace the metal fuel pump to carb line and It looks like it would be a WHOLE lot easier if I screw it on the pump then install the pump back on the engine.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | You don't have to remove the fuel pump to replace the metal fuel line. If you remove the fuel pump you might have to put in a new fuel pump gasket. So you're better off not removing the fuel pump.
Just make sure you don't cross the threads when screwing on the metal fuel line. When you start to thread on the pipe fitting nut into the fuel pump port, and it starts turning hard, that will tell you the threads are crossed. The pipe fitting nut should turn fairly easy until it bottoms out. You may have to bend the pipe slightly to get the pipe fitting nut threads to line up with the fuel pump port threads.
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Thank you for helping me not create more work for myself!
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | I'd recommend attaching the fuel line to the pump before the carb end. Keep it loose until you attach the carb end. Once you have both ends connected, them tighten them.
1959 3100 Apache Fleetside
