| | | Forums66 Topics128,047 Posts1,055,533 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | 58gmc 1/2ton truck gmc302 with Holley 4barrel carb. Need assistance from the pedal to the carb. The carb opens towards the grill. How can I get it to work? Thanks
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If any of the throttle shaft arm hangs below the throttle shaft drill a hole UNDER the throttle shaft and this will reverse the direction of the pull. If nothing hangs down then tack or bolt something to the throttle arm that will hang down.
Evan
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Is there a way I can use a cable set up? What would I need?
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Cable is the only way to go and much better than the factory rods, bell crank, pivot pin Rube Golburg set up. We use Ford cables because it uses a small round hole in the firewall vs the square hole required for a GM and has a built in return spring. If your pocket book is strong then Lokar makes a very nice set up for just about any application. Pictures: http://s32.photobucket.com/user/coilover/media/S10%20053.jpg.htmlhttp://s32.photobucket.com/user/coilover/media/S10%20050.jpg.html First shot shows cable through firewall at about the 11 oclock position above the brake booster. Second shows blue integral return spring on the Ford cable
Evan
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | That's for a v8.I'm dealing with a 6cylinder.Does that matter. That gmc302 is a 6cylinder that came out of a deuce in half truck from the early 50's.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The function of an accelerator cable is connect the carburetor to the accelerator pedal---engine makes no difference.
Evan
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I just went through this on my 53, used a 36" flex cable from Summit. Tried to jury rig a couple other ideas but the flex cable is great, smooth and no issues. I did use the 'spoon' type pedal, hard part was finding the best place to mount that. Best of luck | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Might also check out the Lokar site for cable setup | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | yeah they sure do have a lot at their site....
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | So I ordered the Lokar stuff that was recommended to me by a tech. Can I make the throttle cable push the carb linkage instead of pull?
Ordered Lokar parts : pedal #xfmg-6098 ; cable # xtc-1000ht36 ; carb bracket # xsrk-4000; pedal spacer xgps-6016
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | The reason I went with the cable was to get away from the mechanical linkage. The way the carb sits now I would need to "push" it to work. Guess I might have to rotate the carb.
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | dtwbcs, Pull vs Push, that's the rub with this set up, as I mentioned tried a couple methods and nothing worked smoothly. So the solution was the Lokar cable from Summit along with the modern 'spoon' type pedal and it works like a dream, like a new car. Will try to send you a couple pics via pm. Also my carb is mounted cross ways (unlike a V8) puts the primaries inline with the motor/intake, so I needed the 36" cable to make the big loop and not kink.
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Lokar stated it is a "pull" only set up. I'm good with that; so I need to rotate the carb; redo the fuel line
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Rotating the carb 90 degrees is what most of my Inliner friends have recommended. I am really happy with this set up on my 53 flatbed. Best of luck Also notice the pics of the 292 motor on this thread, that carb is also rotated vs facing forward.
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | So I bought both Lokar pedals : the Eliminator and a spoon pedal. I want to put one in my 58gmc truck with the cable setup. Anybody use either pedal?  The Eliminator looks more like a standard pedal. PLUS in order to mount they would be close to the brake pedal?.
