| | | Forums66 Topics128,006 Posts1,055,272 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 68 | Hi all I think I'm in the right place. I have found an engine for my 42 1 1/2 ton truck but just need to ID it The engine number is BTR 542014 and cast numbers 839910 1 42 Cheers Justin | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Justin, The VIN Buster does not recogonize your engine #. Harold
Your 'VIN Buster' Results ... Serial # : BTR542014 Mfg Year : unknown Model : Style : Pickup Plant : unknown
Harold Is a restoration ever finished? | | | | | Joined: Jan 2010 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 68 | Thanks everyone, just had another look at block casting numbers and there are only 6 digits and is the same as my old block it may be an Australian thing but my original engine and truck was built in USA . They other numbers tell me that the engine is a August 1943 block so that is good, another small thing I found is that that oil line t hat passes through the water jacket on my original block between piston 4/5, the 43 block has the line through the sump/ crank shaft. I think it is a better idea ???? Cheers Justin | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | I deleted my first post in this thread to prevent future confusion. The 839910 is a good USA number and it does show up in my 1929-51 Chevrolet Master Parts Book. It lists it as a 1942-47 216 Block and also lists 839770 as a 1942-47 216 Block. Mike B  | | |
