4 members (3B, MickeyP, 1955 1 Series, 1 invisible), 47 guests, and 3 robots.
Topics128,012
Posts1,055,321
Members48,419
#1222148 06/21/2017 7:45 AM
Hi all
I think I'm in the right place. I have found an engine for my 42 1 1/2 ton truck but just need to ID it
The engine number is BTR 542014 and cast numbers 839910 1 42
Cheers Justin
Aus42blackout #1222176 06/21/2017 5:02 PM
Justin,
The VIN Buster does not recogonize your engine #.
Harold
Your 'VIN Buster' Results ...
Serial # : BTR542014
Mfg Year : unknown
Model :
Style : Pickup
Plant : unknown
Harold
Aus42blackout #1222177 06/21/2017 5:10 PM
1942 Chevrolet Truck Vehicle Serial Number codes
But, those are for USA - yours might be Canadian or Holden?
Mike B #1222195 06/21/2017 8:37 PM
I trust Mike.
This info is from a variety of Internet-found sources:
839910 - 1941-1947 216
The locations might be shown here.
Aus42blackout #1222223 06/22/2017 1:26 AM
Thanks everyone, just had another look at block casting numbers and there are only 6 digits and is the same as my old block it may be an Australian thing but my original engine and truck was built in USA .
They other numbers tell me that the engine is a August 1943 block so that is good,
another small thing I found is that that oil line t hat passes through the water jacket on my original block between piston 4/5, the 43 block has the line through the sump/ crank shaft. I think it is a better idea ????
Cheers Justin
Aus42blackout #1222230 06/22/2017 1:45 AM
I deleted my first post in this thread to prevent future confusion.
The 839910 is a good USA number and it does show up in my 1929-51 Chevrolet Master Parts Book. It lists it as a 1942-47 216 Block and also lists 839770 as a 1942-47 216 Block.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
