1 members (Rich'sToys), 166 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
1954 Chevy 3600 with fuel unit on top of the tank. All I can find is a five hole gasket but need the six hole one. Leaking and getting raw fuel smell in the cab. Thanks in advance for direction. Also is this cork or rubber? Thanks!
1954 3600
Crusing in the Passing Lane
Make your own, get a gasket punch set-very useful-and scissors.
Ed
Roger that!
Cork or Rubber?
1954 3600
Ex Hall Monitor
Ex Hall Monitor
The original on my '38 was cork. I'd go with modern neoprene. Cork can be porous. FWIW I never heard of a six hole sender.
That must be it. Looking at the way the unit is mounted on the tank, it appeared all of the screws holding it in place are the same size. Guess I was thrown off by one of the holes in the gasket being smaller. I will give it a go and thank you!
1954 3600
All the holes are the same, but they are not evenly spaced. It may take a try or two to get it located correctly.
' Offline
Here's a photo of my 1954 3600 gas tank
showing the top cover of the gas guage sending unit .
photo@photobucket
http://i669.photobucket.com/albums/...as_Tank_1954_Chevy_3600__zpsyf4efgqy.jpg
photo of 1954 3600 gas guage tank unit
http://i669.photobucket.com/albums/...age_Unit_AC_NOS_1516999__zps0gsj9qj2.jpg
photo of original cork gasket made by GM
http://i669.photobucket.com/albums/...ork%20Gaskets%20GM%20NOS_zpscyoi3upb.jpg
photo of neoprene gasket that replaced the cork gasket
in ( 1979 ) .
http://i669.photobucket.com/albums/...prene_Gasket_GM_1516395__zpsm3e9ihvk.jpg
photo of the sending unit cover bolts by GM
http://i669.photobucket.com/albums/..._Cover_Bolts_GM_3767804__zpsx2ubhzvw.jpg
I would NOT use one of those cheap made in china gaskets
on my truck. I highly suggest using a gasket made
by GM . You certainly have choices .
I used the cork gasket on my truck .
Does ethanol gas have an effect on neoprene ?
What's the made in china gasket made of ? Who knows !
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Thank you for the additional pics and info.
This is what I am looking at: PhotoBucket
1954 3600
I would also double the filler hose of the gas tank. I had a problem with gas smell and found the rubber hose that connects the filler tube on the outside of the truck to the metal tube feeding the tank on the inside of the cab had a loose connection. Over the years all the movement had the rubber hose almost pulled off on the low end. The hose clamp was not very tight either. When I would fill up gas would leak out around that connection into the cab.
Dave from Northern Kentucky
My 54 3100
' Offline
I have no idea what vehicle your gas tank is from .
The photo in my first post showing my 1954 3600
gas tank is the original tank to my truck.
Obviously your tank has been changed at some point .
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Was thinking the same thing after seeing your pics. I just got the truck a few months ago. The truck has been modified with a 327 Chevy small block under the hood with a TH350 transmission two owners ago.
1954 3600
