5 members (Hotrod Lincoln, Southerntruck, Ponchogl, cmayna, 1955 1 Series), 186 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
Junior Member
Junior Member
I need some help with the wood and rubber blocks under the cab on my 45. Do the wood blocks go at the front of the seat and the 1 1/4 rubber blocks go at the rear of the cab? Right now the front of the cab is on the frame and the rear is jacked up 1 1/4 is that corect?
Check the tech tips section there is a post on 41-46 cab mounting.
The crew that works on the \'42 --Sara, Hannah and Abby
Junior Member
Junior Member
Thanks fellas tech tips was perfect
