Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (klhansen), 136 guests, and 10 robots.
Topics128,281
Posts1,058,470
Members48,490
Junior Member
Junior Member
I need some help with the wood and rubber blocks under the cab on my 45. Do the wood blocks go at the front of the seat and the 1 1/4 rubber blocks go at the rear of the cab? Right now the front of the cab is on the frame and the rear is jacked up 1 1/4 is that corect?
Check the tech tips section there is a post on 41-46 cab mounting.
The crew that works on the \'42 --Sara, Hannah and Abby
Junior Member
Junior Member
Thanks fellas tech tips was perfect
