| | | Forums66 Topics128,277 Posts1,058,448 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 16 Junior Member | | Junior Member Joined: Mar 2006 Posts: 16 | I need some help with the wood and rubber blocks under the cab on my 45. Do the wood blocks go at the front of the seat and the 1 1/4 rubber blocks go at the rear of the cab? Right now the front of the cab is on the frame and the rear is jacked up 1 1/4 is that corect? | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | Check the tech tips section there is a post on 41-46 cab mounting. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | | | | | | Joined: Mar 2006 Posts: 16 Junior Member | | Junior Member Joined: Mar 2006 Posts: 16 | Thanks fellas tech tips was perfect | | |
