4 members (WICruiser, Gray_Ghost, Bill Hanlon, Nick in Manitou), 125 guests, and 2 robots.
Topics128,109
Posts1,056,269
Members48,439
#1219698 06/02/2017 2:00 AM
I replaced the master cylinder on my 58 step van and the brake pedal only goes down only slightly. The last cylinder was dead and I had no brakes, so I'm unsure of correct brake pedal travel. The brake light switch is now unable to trip because of the short travel of the pedal. should I adjust the bracket that places the switch in the pedals path? Maybe too much fluid? I sure would appreciate any comments or suggestions. Thanks, Chaz
1958 Chevy Grumman Olson step van
Before you replaced the MC did the truck roll and stop?
Are any of the wheel cylinders frozen up?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Did you adjust the rod that pushes the MC piston so the pressure in the brake lines can release as the pedal hits the stop? After a few brake applications you might be getting a solid stack of fluid from the master cylinder to the wheel cylinders, the pedal will be very high, and all the brakes will drag.
Thanks guys, I'll take a second look tomoorow.
Hey Jerry, I think your deduction is the most plausable. I found the return spring was worn out and now have a new one installed. The pedal is very high, and brake only goes down maybe a couple inches. How can I reduce the stack of fluid? Bleed? Thank you, Chaz
Chaz 58 #1219805 06/02/2017 11:51 PM
First, adjust the master cylinder pushrod so it takes about 3/4" to 1" of pedal travel before the M/C piston starts to move. To get the pressure off the system, crack any one of the bleeder screws open at one of the wheels and you'll probably get a quick squirt of fluid. John's fire truck was doing the same thing at the Homecoming, and shortening the pushrod a little solved the problem. Good luck!
Shouldn't simply adjusting the push rod to the correct length allow the piston in the master cylinder to return to the fully released position, exposing the port allowing the fluid to return to the reservoir?
Yes, theoretically. If there's more than one problem, like a collapsed flex hose, for instance, it might be necessary to vent a wheel cylinder. The problem will come back even with the right M/C stroke if that happens but only one or two brakes will drag.
does the new master cylinder have the same bore as the old one? If the new one has a larger bore it will move more brake fluid per stroke. just thinkin
