0 members (),
68
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 69 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 69 | I want like to add a heater/defroster to my 1952 Chevy Pickup. It has a 235ci engine and has been converted to 12 volts. I would appreciate any suggestions and comments related to installation and operation of an original or one of the aftermarket heater/defroster units available. Dan
| | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | There are lots of options. A couple of the more common ones are the deluxe heater and the recirculating heater. The recirculating heater is less complicated and seems to be more readily available used. I went this route with my 1952 and after struggling with a leaking heater core several times I went with a new Brassworks core and fan. I posted about that here https://www.stovebolt.com/ubbthread...rks_Recirculating_Heate.html#Post1011395 | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I've got an original Fresh Air heater in my '53 and it works great. I'm not living in Michigan but on a couple -30° mornings here in Iowa I was glad to have that heater. The real trick is to seal your cab up or the draft will pull all the heat out. This old heater is good enough that on 25° - 30° days I have to crack the window if I'm cruising through town. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 |
Ed
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The recirculating heater in the installation manual at Ed's link above is unlike the recirculating heater in Chuck's link (which is the recirculating heater I am familiar with). I had a recirculating heater in my 54 pickup which I bought in a cold Dec, and drove it 120 miles in 6 degrees. The windows were rattling from no seals, but that heater kept me toasty warm. | | |
