1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | I understand that a special flasher is needed when changing to LED taillights. Do the front directional bulbs need to be changed to LED because of the new flasher and also a camper that I pull with the truck. Will it also need LEDs? Dave | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Dave, I am running LED taillights with incandescent fronts and regular flasher. Works fine for me.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I've done the same as Dennis.
| | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | As long as one pair is regular no special flasher needed. All LED special flash required. | | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | thanks for the info guys. Dave | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I must just be "lucky". I put LED tail light bulbs in my '03 pickup and had to change the flasher even though I left the incandescent bulbs in front. I had the dreaded hyperflash.
| | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | Follow-up on the LEDs. I finally installed the LED units on my 49 and was able to keep the original flasher. It actually works better than before. It now has a nice distinct flash as opposed to a rapid flash that it had before. Much brighter and safer now. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 15% off LED auto/truck bulbs (these are much brighter than original) - common bases for our trucks - 12v - 6v positive/negative ground (many common bases) No 6v head lamp, yet | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I ran LED Rear and incandescent front with an electronic flasher with no problem. But just today I installed the new LED in front, and tomorrow I have to be making a stop at my FLAPS to part with some coin for either anew flasher or a load equaliser? to make em' blink. Still glad to get away from the bulbs and the problems that comes with them. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | dj,
Please let us know the brand and part number of flasher, if/when it works.
| | | | | Joined: Jun 2009 Posts: 789 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 789 | First of all--Happy Memorial Day to all--remember the fallen! Yesterday I installed Super Bright RED 6V LEDs at the rear of my truck, using the same flasher as before the LEDs arrived. I am very happy; I like the brighter visibility! Time to take the old gal out for a little country drive today  | | |
