4 members (rick46ia, Hotrod Lincoln, Otto Skorzeny, 2-Ton), 101 guests, and 2 robots.
Topics128,034
Posts1,055,547
Members48,425
#1216519 05/09/2017 12:57 AM
I understand that a special flasher is needed when changing to LED taillights. Do the front directional bulbs need to be changed to LED because of the new flasher and also a camper that I pull with the truck. Will it also need LEDs? Dave
DaveV #1216520 05/09/2017 1:01 AM
Dave, I am running LED taillights with incandescent fronts and regular flasher. Works fine for me.
Dennis
40 Chevy 1/2 ton
DaveV #1216563 05/09/2017 4:23 AM
I've done the same as Dennis.
DaveV #1216572 05/09/2017 5:21 AM
As long as one pair is regular no special flasher needed. All LED special flash required.
DaveV #1216589 05/09/2017 11:31 AM
thanks for the info guys. Dave
DaveV #1216624 05/09/2017 5:46 PM
Ex Hall Monitor
Ex Hall Monitor
I must just be "lucky". I put LED tail light bulbs in my '03 pickup and had to change the flasher even though I left the incandescent bulbs in front. I had the dreaded hyperflash.
DaveV #1218638 05/25/2017 12:04 PM
Follow-up on the LEDs. I finally installed the LED units on my 49 and was able to keep the original flasher. It actually works better than before. It now has a nice distinct flash as opposed to a rapid flash that it had before. Much brighter and safer now.
DaveV #1218692 05/25/2017 6:09 PM
15% off LED auto/truck bulbs (these are much brighter than original)
- common bases for our trucks
- 12v
- 6v positive/negative ground (many common bases)
No 6v head lamp, yet
DaveV #1218850 05/27/2017 1:31 AM
I ran LED Rear and incandescent front with an electronic flasher with no problem. But just today I installed the new LED in front, and tomorrow I have to be making a stop at my FLAPS to part with some coin for either anew flasher or a load equaliser? to make em' blink. Still glad to get away from the bulbs and the problems that comes with them.
dj durant
More pix on Flickr
DaveV #1218851 05/27/2017 2:13 AM
dj,
Please let us know the brand and part number of flasher, if/when it works.
First of all--Happy Memorial Day to all--remember the fallen!
Yesterday I installed Super Bright RED 6V LEDs at the rear of my truck, using the same flasher as before the LEDs arrived. I am very happy; I like the brighter visibility!
Time to take the old gal out for a little country drive today smile
