1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
#1218442 05/23/2017 11:29 PM
I posted the note below in the parts wanted forum but now I'm thinking about making this fastener myself.
A couple of years ago "I found this neat radiator cover under the seat of the '53 3100 that I bought at auction: https://www.dropbox.com/s/euvju6hr1aha3tp/Radiator%20cover.jpg?dl=0 I also found these installation instructions: https://www.dropbox.com/s/chhkohi00sw7fa3/Radiator%20cover%20installation%20instructions.pdf?dl=0
Problem is that the "special fasteners" referred to are nowhere to be found. Anyone know where I could find some?"
But the illustration on the left in the instructions shows a "screen assembly" which means I'm missing more parts. Has anyone seen one or have a clue about how this assembly looks? Thanks
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
Cool find.
Tractors use similar. Do a search for "cub cadet grille springs". They should work.
The "screen assembly" is the cover itself, not some additional part.
Good luck.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Brian
1955.2 3100 Truck
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Thanks! The help that I've received on this forum is outstanding.
~Denny
1953 Chevy 3100
