10 members (DadsFirstPickup, TUTS 59, JW51, GRNHydra, Ponchogl, GradyB, Leo, Jon G, walterhvogel, 1 invisible),
50
0
Mod | | | Forums66 Topics128,080 Posts1,055,944 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | I posted the note below in the parts wanted forum but now I'm thinking about making this fastener myself. A couple of years ago "I found this neat radiator cover under the seat of the '53 3100 that I bought at auction: https://www.dropbox.com/s/euvju6hr1aha3tp/Radiator%20cover.jpg?dl=0 I also found these installation instructions: https://www.dropbox.com/s/chhkohi00sw7fa3/Radiator%20cover%20installation%20instructions.pdf?dl=0 Problem is that the "special fasteners" referred to are nowhere to be found. Anyone know where I could find some?"But the illustration on the left in the instructions shows a "screen assembly" which means I'm missing more parts. Has anyone seen one or have a clue about how this assembly looks? Thanks
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Cool find. Tractors use similar. Do a search for "cub cadet grille springs". They should work. The "screen assembly" is the cover itself, not some additional part.
Good luck.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 |
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | | | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | Thanks! The help that I've received on this forum is outstanding.
