3 members (David Bush, GRNHydra, Leo), 69 guests, and 2 robots.
Topics128,060
Posts1,055,837
Members48,427
#1210695 03/29/2017 12:22 AM
64 chevy C30 1 ton panel, dropped the tank, cause it had gummed up fuel, had tank inspected, and cleaned, my problem, is that I would like to know if any one here knows where I might find a new fuel sending unit
Wylie johnson
wylie #1210721 03/29/2017 2:33 AM
Leo Online: Content
Moderator
Moderator
Not sure if your FLAPS carries them, they might. Otherwise go to the top of the page and click on 'links' then 'parts', lots of suppliers.
wylie #1210729 03/29/2017 4:07 AM
Sir Searchalot
Sir Searchalot
GM should have used the same one for all trucks. Panels and suburbans are different.
Maybe you don't know any aftermarket 60-66 vendors yet. Here is a sender that may be the one.
wylie #1210743 03/29/2017 10:15 AM
nope I have one and that is for a truck
Wylie johnson
wylie #1211057 03/31/2017 8:30 PM
Sir Searchalot
Sir Searchalot
I found the right one for Panels by googling.
wylie #1218149 05/22/2017 12:05 AM
well after looking, still no luck on finding a sending unit for my 1 ton C30 panel, I did get it cleaned, reinstalled, and put tank back in, now it reads full when I turn on the key, all wiring is correct, so now I am going to remove the tank, to see if the sending unit is stuck in the full up position, if not I will look for a different kind, and make it work.
so if any one here has a panel with a side mounted tank, and a good sending unit, let me know
Wylie johnson
wylie #1218160 05/22/2017 1:15 AM
If it reads full, you might not have the sender grounded. Run a wire from a sender mounting bolt to a good/clean ground.
This assumes the gauge goes back to zero when the ignition is off?
wylie #1218813 05/26/2017 9:40 PM
panel had been setting in field, when I got her home, I did not put a battery in her to see what electric was good, so the gage read 1/2 full, when I did get a battery, the tank had old fuel, hence is why I dropped the tank, no one has this fuel sender, and I have 2 that the parts people said that would work, they are for a truck, so I cleaned mine up checked it with a ohm meter and it showed ok 0 ohms down, 30 ohms up or full, so I am going to take the tank back out and see if the float is stuck in full or if sender is any good, will let all know what I find
Wylie johnson
wylie #1218823 05/26/2017 10:25 PM
Run a ground wire from a sender attachment screw to some clean metal/bolt/screw on the frame (right side, if you find a ground place).
wylie #1218858 05/27/2017 2:54 AM
Do not waste any time removing the tank until you verify that the top of the sending unit is grounded to a part of the truck which is solidly grounded to the battery.
I hope 3 hints is the charm.
Full reading with ignition on is a textbook symptom for bad ground to sending unit.
Carl
wylie #1226741 07/23/2017 1:52 PM
ok so here is what i found, i went and located the wire that runs from the tank, took it all out, took my ohm meter, and checked it, no continunity, so i looked to see if there was a brake in the line, and i found that the top that goes to the sending unit was broken, the rubber protector hid the part that goes to the sending unit, went to parts store and found a connector that fit, installed it and low and behold, the gauge works, went and filled her up and i watched as i filled her up and she reads, so problem fixed, want to thank all here, for all the info, and the help
Wylie johnson
