3 members (TexasA&M48Truck, TUTS 59, Stovebolt48), 62 guests, and 8 robots.
Topics128,021
Posts1,055,348
Members48,420
#121714 08/18/2006 1:17 AM
Not sure if best posted here or in Paint and Body.
What, if there is such a paint, is a bullet proof high temp paint for my Fenton Exhaust Headers?
And what preparation is needed?
I just don't want to go to the expense of the ceramic coating; ($150 here in Southern Calif).
Also has to be backyard simple to apply. :p
#121715 08/18/2006 2:00 AM
Chevy Duty has a high temp manifold paint. It's supposed to look like stainless and they call it that. It's more like cast iron silver once applied. It brushes on easily. Check out this pic. The intake is the paint. The headers are ceramic coated with "chromex". http://community.webshots.com/photo/360111285/1360112035071636143AcMuuA
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#121716 08/18/2006 4:45 AM
bigmacdaddy,
Looks good, but the intake isn't the test.
Rust will prevail, quickly, if the paint is porous.
Since you have the exact setup that I'm doing, why would you paint the aluminum intake?
On another not, I noticed a set screw plug in the front header. Where did you get that? And how did it fit? How many turns did you get?
#121717 08/18/2006 4:36 PM
That intake is the original cast iron, not aluminum. The paint is supposed to work on the headers as well. I also used it to paint the waterpump, thermo housing, coolant lines to the intake, the transmission case and the master cylinder. So far it has held up well in all areas. The plugs for my headers came from napa. I don't remember how many turns, but it doesn't leak and went in easy. I will be installing an aluminum Edelbrock 2 x 1 on my 261. I still haven't decided if I will coat it or not.
My Webshot Photos]
#121718 08/19/2006 12:48 AM
It was such a good shade for aluminum that I thought it was the Offenhauser. Sorry, my mistake.
#121719 08/19/2006 4:13 AM
I don't know what is but, I used a DupliColor heat paint on my long tubes before installing them. It was aluminum color and supposed to be good to like 2000 degrees or something. The headers looked very nice. Then I installed them and started the truck. They smoked and bubbled horribly in the first 5 minutes. After that, it just began to flake off. Really a drag. Don't get that one.
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#121720 08/21/2006 12:07 AM
Junior Member
Junior Member
go to the hardware store and get barbque paint its cheaper than header paint and same stuff. had it on my long tube headers lasted for 3 years
bcm55
#121721 08/21/2006 2:42 AM
www.eastwood.com has alot of stuff like that
64 c10
89 rs
62 econoline
50 ford coupe
