3 members (k2handyman, Youngin' Tut 59, 78buckshot), 74 guests, and 3 robots.
Topics128,030
Posts1,055,418
Members48,422
#1216469 05/08/2017 4:46 PM
Z
Z Offline
after many years of searching I finally found old east ridge engine 2 a 1948 chevy 6400 custom built into a fire engine
foreseeable issues are sourcing brake parts any help is greatly appreciated
I cant get it to link pictures if you would like to see it search East Ridge Fire Department pre 1993 on facebook
Zach
Zach Q #1216556 05/09/2017 3:36 AM
Welcome to the Stovebolt wave
For your mechanical issues drop down into the regular "Big Bolt" section and ask away, you'll get lots of help there. The Fire Bolt section is best for fire equipment related questions.
You will be limited in what you can do on site until you have 4 or 5 post under your belt, so start posting questions/comments to get you out of probation...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Zach Q #1216565 05/09/2017 4:32 AM
Z
Z Offline
Awesome thanks for the advice Mike
A little bit more on the truck she is a 48 loadmaster with the 235 strait 6, 4 speed with 2 speed rear, open cab with custom made fire bed 500 gpm darley pump and im not sure on how much water she will hold. she has been sitting since the 90s under cover hopefully i will have her up running and driving by the fall.
if anyone has any old fire equipment they are looking to get rid of im looking for a wooden ladder, pike poles, pick head axe, extinguishers etc.
also looking for some red glass lenses with fire etched in them for the tail lights and one light on the engineer fender
dont have any measurements for them right now but i will soon
photobuckett
Zach
Zach Q #1216802 05/11/2017 3:53 AM
Neat truck thumbs_up You'll have lot of fun driving it around!
Wooden extension ladders are not to hard to find, keep a eye out at local farm auction/sales. They can be cut if you find one thats to long. The roof ladder may be a little harder to find.
Measure the lens you need and do a search on ebay, there are always glass lenses for sale there.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Zach Q #1216803 05/11/2017 4:08 AM
Moderator
Moderator
2 Offline
Welcome to the FireBolt club Guintrell.
You'll find that Mike B. will not steer you wrong.
Mike, roof ladder, is that the type with the big loops on the end?
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Zach Q #1216805 05/11/2017 4:42 AM
Yes Don, the roof ladder will have swing out hooks to allow it to be hooked over the ridge of the roof or to hook on a balcony rail and leap frog your way to the top of a building. It will also be narrow enough to nest inside the Base Section of the extension ladder (same size as the Fly Section) when racked on the truck.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Zach Q #1216853 05/11/2017 5:37 PM
Might want to check with your local FD. Some times when a ladder fails it's annual service test they send it to the aluminum scrap recycle bin. If you can convince the FD it will not be used other than on an antique pumper or ladder truck , you might be able to get one. Havent seen any wooden roof ladders but you might be able to find a vintage pompier ladder, they are cooler than a run of a mill roof ladder anyday. Most are out of service unless you live in a third world country.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Zach Q #1216870 05/11/2017 7:04 PM
Big Bolt Forum Moderator
cool truck! Welcome to the site!
Mike
Zach Q #1216879 05/11/2017 9:14 PM
Moderator
Moderator
2 Offline
As you can see Quint.
Your in good company here.
Thanks Mike, I thought that and the truck came with one.
But I had to look up pompier ladder.
http://www.fireserviceinfo.com/pompierladders.html
Don
"The Flag Pole"
1953 1-ton pickup
Mike B #1219174 05/29/2017 6:44 PM
Thanks for the tip!
Moderated by  69Cuda
