2 members (gswbbc, Gray_Ghost),
50
Mod | | | Forums66 Topics128,035 Posts1,055,446 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2017 Posts: 5 New Guy | | New Guy Joined: May 2017 Posts: 5 | after many years of searching I finally found old east ridge engine 2 a 1948 chevy 6400 custom built into a fire engine
foreseeable issues are sourcing brake parts any help is greatly appreciated
I cant get it to link pictures if you would like to see it search East Ridge Fire Department pre 1993 on facebook
Zach
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Welcome to the Stovebolt  For your mechanical issues drop down into the regular "Big Bolt" section and ask away, you'll get lots of help there. The Fire Bolt section is best for fire equipment related questions. You will be limited in what you can do on site until you have 4 or 5 post under your belt, so start posting questions/comments to get you out of probation... Mike B  | | | | | Joined: May 2017 Posts: 5 New Guy | | New Guy Joined: May 2017 Posts: 5 | Awesome thanks for the advice Mike A little bit more on the truck she is a 48 loadmaster with the 235 strait 6, 4 speed with 2 speed rear, open cab with custom made fire bed 500 gpm darley pump and im not sure on how much water she will hold. she has been sitting since the 90s under cover hopefully i will have her up running and driving by the fall. if anyone has any old fire equipment they are looking to get rid of im looking for a wooden ladder, pike poles, pick head axe, extinguishers etc. also looking for some red glass lenses with fire etched in them for the tail lights and one light on the engineer fender dont have any measurements for them right now but i will soon photobuckett
Zach
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Neat truck  You'll have lot of fun driving it around! Wooden extension ladders are not to hard to find, keep a eye out at local farm auction/sales. They can be cut if you find one thats to long. The roof ladder may be a little harder to find. Measure the lens you need and do a search on ebay, there are always glass lenses for sale there. Mike B  | | | | | Joined: Aug 2001 Posts: 3,588 Moderator | | Moderator Joined: Aug 2001 Posts: 3,588 | Welcome to the FireBolt club Guintrell. You'll find that Mike B. will not steer you wrong.
Mike, roof ladder, is that the type with the big loops on the end?
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Yes Don, the roof ladder will have swing out hooks to allow it to be hooked over the ridge of the roof or to hook on a balcony rail and leap frog your way to the top of a building. It will also be narrow enough to nest inside the Base Section of the extension ladder (same size as the Fly Section) when racked on the truck. Mike B  | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Might want to check with your local FD. Some times when a ladder fails it's annual service test they send it to the aluminum scrap recycle bin. If you can convince the FD it will not be used other than on an antique pumper or ladder truck , you might be able to get one. Havent seen any wooden roof ladders but you might be able to find a vintage pompier ladder, they are cooler than a run of a mill roof ladder anyday. Most are out of service unless you live in a third world country. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | cool truck! Welcome to the site! | | | | | Joined: Aug 2001 Posts: 3,588 Moderator | | Moderator Joined: Aug 2001 Posts: 3,588 | As you can see Quint. Your in good company here. Thanks Mike, I thought that and the truck came with one. But I had to look up pompier ladder. http://www.fireserviceinfo.com/pompierladders.htmlDon 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: May 2017 Posts: 4 New Guy | | New Guy Joined: May 2017 Posts: 4 | | | |
