Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (mo2cyl, Rusty Heaps), 59 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#121671 08/15/2006 11:46 PM
I just got 2 gallons of black last week and have a few questions about it. First off has anyone sprayed this stuff before I have read the instructions and know you can thin it with solvents but it did not specfiy any ratio. So I need help with that and I plan on using a HVLP gun with a 1.5 tip. Is this too small of a tip? Any answers with be helpful. I will get some pics on here in the near furture. Thanks again.
Get busy liv'n or get busy die'n
#121672 08/16/2006 1:18 AM
Anonymous
Unregistered
Anonymous
Unregistered
hey chazwel,I just got a gallon of red oxide and a gallon of black.I'm gonna use a HVLP gun with a 1.7mm nozzle to spray mine on this week.You can thin it 15 to 20%.I'll let you know how it goes.
#121673 08/16/2006 1:47 AM
Hey guys Any tip from 1.4 to 1.7 should do fine for applying ZR. thinning then becomes a function of finding a sprayable consistancy you like. Start at 10 o 15% and work from there. One thing to make sure of is you get it mixed well. ZR is high in solids and if it has been sitting, get the goody up off the bottom and well disbursed. Allow flash off time between coats and pay attention to film thickness. It it really easy to over apply. The two coat two color thing, like black over red oxide is a good visual barometer to help you know where you've been. Get a good paint fume mask and don't worry about isocyantes as there are none in ZR.
Call me if you have any questions.
800-725-4960
