| | | Forums66 Topics128,012 Posts1,055,321 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 48 New Guy | | New Guy Joined: Mar 2004 Posts: 48 | I just got 2 gallons of black last week and have a few questions about it. First off has anyone sprayed this stuff before I have read the instructions and know you can thin it with solvents but it did not specfiy any ratio. So I need help with that and I plan on using a HVLP gun with a 1.5 tip. Is this too small of a tip? Any answers with be helpful. I will get some pics on here in the near furture. Thanks again.
Get busy liv'n or get busy die'n
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | hey chazwel,I just got a gallon of red oxide and a gallon of black.I'm gonna use a HVLP gun with a 1.7mm nozzle to spray mine on this week.You can thin it 15 to 20%.I'll let you know how it goes. | | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | Hey guys Any tip from 1.4 to 1.7 should do fine for applying ZR. thinning then becomes a function of finding a sprayable consistancy you like. Start at 10 o 15% and work from there. One thing to make sure of is you get it mixed well. ZR is high in solids and if it has been sitting, get the goody up off the bottom and well disbursed. Allow flash off time between coats and pay attention to film thickness. It it really easy to over apply. The two coat two color thing, like black over red oxide is a good visual barometer to help you know where you've been. Get a good paint fume mask and don't worry about isocyantes as there are none in ZR. Call me if you have any questions. 800-725-4960 | | |
