| | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 17 Junior Member | | Junior Member Joined: Jul 2006 Posts: 17 | if iwas gonna sand down my truck when i could get the time and it was gonna be spread out his there a priemer i can put on that will keep what ive done in good shape and wont cusse a bunch head ace when paint time come it will see the weather
You have to stand for somthing or you will fall for anything
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I used Rust-Oleum sandable auto primer. Dries fairly quickly and is easy to sand when the time comes for finishing.
Bill Burmeister | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | I'll second that about the Rust-Oleum wet sandable primer. When I've finished stripping the rust and paint off an area, I'll spray it right away. In the beginning...I was spraying some WD-40 on a rag and wiping it down to keep it from flash rusting, everybody in here set me straight on that. DON'T DO IT! I removed the WD-40 with some degreaser, then primered it. http://community.webshots.com/user/mummdogg | | | | | Joined: Apr 2005 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 20 | i was always told that a light clear coat will work.keeps the moisture out of the primer till you want to paint and the prep is the same. you can get it in spray cans so if your doing a spot at a time and it will be awhile before you paint this might work for ya.i havent actually tried this so i dont know but it sounds good. | | |
