3 members (mick53, UtahYork, Gdads51), 66 guests, and 2 robots.
Topics128,090
Posts1,056,018
Members48,430
#1215294 04/30/2017 1:37 AM
Trying to install new points and condenser. How do you loosen the screw where the condenser wire attaches? Special tool required?
Yes, there is a tubular tool with two prongs that engage the slots in the nut that holds the point spring and the condenser wire in place. A pocket screwdriver with a very narrow tip can be used to engage one side of the slotted nut, or a short-bladed common screwdriver can have a slot ground in the center to clear the stud. I like to use a piece of 5/16" or 3/8" steel fuel line about 3" long with one end filed to engage the nut and the other end drilled for a piece of 3/16" round stock as a handle.
Once again its Jerry to the rescue! Thanks!
Jim
Check Ebay for "Delco distributor tool" There were several of them there recently.
I have three of those tools that belonged to my dad
and I will not part with any of them.
Though I do have a fourth one that was never used and
I will send it to you for whatever it costs me to send
to you. Jeffrey
Have one right here, KD tools # 2025
I just went to my garage and cannot find the fourth one.
At this point I have to apologize for not being able to
make good on my offer. If I ever find it I will PM you
to see if you have not been able to find one.
Jeffrey
Thanks Crowjam and HotRod Lincoln. I couldn't sleep last night so I was browsing the forum. Being the tool junkie I am, there's one less on E-Bay. I could have probably made one, but I like experienced tools and the price suited me. Someday my wife is going to have a heck of an auction, but she said I need to label everything because nobody else will know what it is! John
I like the double-ended tool that has a hex nut driver on one end and the 2-pronged spanner on the other- - - -one less tool to misplace that way!
Anyone care to guess why they would create a design like that?
1951 1 Ton Completed
Riding in the Passing Lane
It made it easier to draw up the connections then using a open end wrench on the inside. I still have the one I used 65 years ago.
1972 Chevy c10 Cheyenne Super
