2 members (Thomaslb, Eddie54),
166
0
Mod | | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2017 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 43 | Trying to install new points and condenser. How do you loosen the screw where the condenser wire attaches? Special tool required? | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Yes, there is a tubular tool with two prongs that engage the slots in the nut that holds the point spring and the condenser wire in place. A pocket screwdriver with a very narrow tip can be used to engage one side of the slotted nut, or a short-bladed common screwdriver can have a slot ground in the center to clear the stud. I like to use a piece of 5/16" or 3/8" steel fuel line about 3" long with one end filed to engage the nut and the other end drilled for a piece of 3/16" round stock as a handle. Jerry
| | | | | Joined: Feb 2017 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 43 | Once again its Jerry to the rescue! Thanks!
Jim | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Check Ebay for "Delco distributor tool" There were several of them there recently. Jerry
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Trying to install new points and condenser. How do you loosen the screw where the condenser wire attaches? Special tool required? I have three of those tools that belonged to my dad and I will not part with any of them. Though I do have a fourth one that was never used and I will send it to you for whatever it costs me to send to you. Jeffrey | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Have one right here, KD tools # 2025 | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I just went to my garage and cannot find the fourth one. At this point I have to apologize for not being able to make good on my offer. If I ever find it I will PM you to see if you have not been able to find one. Jeffrey | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Thanks Crowjam and HotRod Lincoln. I couldn't sleep last night so I was browsing the forum. Being the tool junkie I am, there's one less on E-Bay. I could have probably made one, but I like experienced tools and the price suited me. Someday my wife is going to have a heck of an auction, but she said I need to label everything because nobody else will know what it is! John | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | I like the double-ended tool that has a hex nut driver on one end and the 2-pronged spanner on the other- - - -one less tool to misplace that way! Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Anyone care to guess why they would create a design like that? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Anyone care to guess why they would create a design like that? It made it easier to draw up the connections then using a open end wrench on the inside. I still have the one I used 65 years ago. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
