7 members (Otto Skorzeny, GrandpasJimmy, Hotrod Lincoln, BarryP, 78buckshot, Mike Roache, Gray_Ghost),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,924 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | My 53 Chevy 1/2 ton has no door locks....Were locks an option for 53 trucks ?
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
| | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | zoegrant,
If you are referring to the inside door lock. If everything in your door hooked up correctly, you should be able to push your door handle the opposite way of when you open your door. It should lock your doors. If you are refering the outside door locks. Back in the day, the factory used to only install a door lock on the passenger side. Anyway, that is how my 53 3100 was setup. Hopefully this helps you out.
Rugo
Steve Rugg 53 3100
| | | | | Joined: Mar 2017 Posts: 326 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 326 | My 56-3200 also has only one keyed lock on the right side. Does anyone know why Chevy did this?
1956 Chevy 3200, 235 w/3 speed
| | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | I have very limited knowledge on the subject. I have been told that a many parking spots were a parallel spot. The streets were not always as wide as they are now. For safety reasons, auto manufactures only installed a outside lock on the passenger side. This was to encougage the driver to exit that side of the vehicle, in order not to open their door into traffic. I don't know that is the reason. But, that is what I was told when I asked someone that drove the 50's trucks, new in the 50's. If somebody else has another explanation, I would be interested in learning more about the reason or reasons also.
Rugo
Steve Rugg 53 3100
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Rugo is correct.
If you look at an old movie with a truck (like one of the last scenes in Hud, for example). You will see drivers getting in/out the passenger door (on street, or, by habit, at their homes).
| | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | Rugo is correct.
If you look at an old movie with a truck (like one of the last scenes in Hud, for example). You will see drivers getting in/out the passenger door (on street, or, by habit, at their homes). Isn't much of a chore in a small old truck with a vinyl bench seat and flat floor. I'm imagining how much of a pain in the rear sliding over to the passenger side would be in my '13 Silverado.  I feel like people look at me funny for getting out of the passenger side when I'm out and about, but they're probably looking at me funny for being in a 67 year old truck. | | | | | Joined: Feb 2008 Posts: 1,123 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,123 | Safety was one reason. But, I have read numerous replies over the years that state it goes back to the days of unpaved streets that often had horse drawn wagons etc. Getting out on the right side, passenger side, kept all riders from getting muddy or dung laden boots. The practice didn't change, for whatever reason, for many years afterward. ((If roads in this modern era get much worse, the practice may see a return)). | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | all about the pennies saved, cars had locks both sides  Bill | | | | | Joined: Mar 2004 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 256 | One more theory, the one I subscribe to till this day, was explained to me by the old guy I bought my truck from. He said it came from days gone by when chivalry was more prevalent....."when trucks were trucks and men were men and women were proud of it". He explained that after a hard week on the farm you'might take your wife/girlfriend/date into town for a dinner/movie. You'd exit your driver's side and close your door and your date would reach over to the inside driver door handle and push it forward to lock your door. She would patiently wait in her seat until you came over to open the passenger side door, extend your hand, and help her exit the vehicle. You could then lock the passenger side door with your key. After dinner, you'd open her door, and she'd get in, and you'd then close her door. As you'd walk around to the driver's side, your date would have reached over to your inside door handle and pushed it rearward one detent, unlocking it so that now you could get in from your own side. And that's the way it is.....other theories aside. Just roll with it...... | | | | | Joined: May 2015 Posts: 11,137 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,137 | That chivalry theory holds some water with me. I once rented a Lincoln town car that had only a lock on the passenger side. When driving a luxury car, one is expected to be chivalrous.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I like 46sparky's "add-on" theory - "get out on the right side for safety and to keep out of the mud/dung". | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I think it was Denny who posted a GM video of a 50 Chevy automobile in which it showed a lady sliding over the seat and saying it was for safety....if my memory is correct tonight!
...my granddaddy, 1887-1971, talked about how the ladies, in a horse and buggy or in a vehicle, would step out onto the wooden boardwalks to keep from getting their pretty dresses dirty! | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I solved the problem. Got a locking door handle for the driver side, too. Keyed to the same key.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | My truck has no outside keyed door locks, previous owner must have replaced the door handle if one lock was supplied on the passenger side. It would be tough sliding across the seat to get out on the passenger side due to the floor shift...
