1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 38 New Guy | | New Guy Joined: Jan 2002 Posts: 38 | Hello,
bought some "new" doors for me 46 gmc. they have been outside for years, all the paint is off, and they have surface rust all over. they are good solid doors with no holes, dents, etc. only the surface rust.
I've never started a repair on this type of rust.
What's the best way to proceed to get these to bare metal for a nice flat paint job?
thanks all for your help.
:confused:
"So many trucks, so little time!"
Vehicle list: down to 2 now. 1 - 1967 Chevy 3/4 ton LWB 4x4 2 - do I dare say it??? a 61 Ford Unibody | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | redbeard if you are sure it is only surface rust and nothing to bad I would have them acid dipped washed and primed ASAP, but if they have a little more than surface rust it will eat a hole in your doors! A good guy on a sand blaster could also clean them up real nice and not warp your doors.
Good luck | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I had my doors dipped by the company that used to be called Redi-strip. They turned out really nice and they only removed rust and paint.
One thing that I found when removing the skins was that there was rust remaning inside the crimped areas. That is just a fact of life as there is no way of getting in there. | | | | | Joined: Jan 2002 Posts: 38 New Guy | | New Guy Joined: Jan 2002 Posts: 38 | thanks for the tips, I will search for a stripper in my area, although I don't think there are any. LaCrosse WI area, anyone know of any?
any other ideas for a low budget project?
i was thinking a light sanding, then phosphoric acid treatment, then sand again, primer, sand again? will that work?
Vehicle list: down to 2 now. 1 - 1967 Chevy 3/4 ton LWB 4x4 2 - do I dare say it??? a 61 Ford Unibody | | | | | Joined: Dec 2002 Posts: 3,442 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,442 | sand them and paint them with "Zero-Rust"?
| | | | | Joined: Jul 2006 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 44 | A cup brush on your grinder will work faster and better than sand paper. imho
Popa Kents Body Shop
| | | | | Joined: Jan 2002 Posts: 38 New Guy | | New Guy Joined: Jan 2002 Posts: 38 | what do you mean by a cup brush?
Vehicle list: down to 2 now. 1 - 1967 Chevy 3/4 ton LWB 4x4 2 - do I dare say it??? a 61 Ford Unibody | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Jun 2006 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 80 | I have been using a wire wheel in my power drill to remove rust alot lately. It seems to do a good job on the underside of the fenders and on the frame. | | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | my thought exactly rusty rod. sand them as smooth as a babys backside. then wipe them clean, and prime them
"you can't fix stupid"
