| | | Forums66 Topics128,064 Posts1,055,859 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2016 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2016 Posts: 28 | I have a 46 Chev which I've owned for 40 years and It was purchased from the original owner. The floor of the box is interlocking wood strips of random widths and no metal strips just oval head carriage bolts holding the wood down to the bed supports. I've seen some restored 46's with equal width boards secured with chrome or painted metal strips just like the more modern 50's-60's trucks. What is correct for 46? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Stan, check out the web site for Mar-K who manufactures bed assemblies. I understand they have some drawings also that may interest you. Also Harold46 would/can be a big help but you cannot PM (private message) anyone until you, as a new member, have made 4 or 5 post. The answer will come just be patient. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Click here for my bed pictures. My metal bed parts are from Mar-K and the bed I made from poplar. Stained with some thinned out green and Minwax poly. Hope this helps..good luck Dan | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | This is information for 47 up trucks but you may find useful. http://gmcpauls.com/47-72_BedWood_Info.htm | | | | | Joined: Mar 2016 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2016 Posts: 28 | Now that I have found my original post thanks for the comments. What I'm after is advice on which floor type is correct for 1946 -all wood or wood with metal strips? I'm not looking to replace mine, just wondering if it is the original floor. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Original...Wood with strips.... Dan
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Original, in '46, would have also used Yellow Pine and not Oak for the wood. | | | | | Joined: Aug 2009 Posts: 193 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 193 | I have owned my 46 1/2 ton since 1973. My bed floor is the same as yours; interlocking wood with no metal strips. I purchased my truck from the second owner, but he did include the original bill of sale for a farmer in South Dakota and the story about the wood bed was handed down: My truck was built in February of 1946 at the Janesville, WI plant. The timing of the plants manufacturing civilian trucks shortly after the wars end came with a caveat; steel was still in short supply! At the time the decision was made to eliminate the steel strips in the bed and about 4 beds would result in saving enough material to make a fender. This is not documented, just the explanation given to the original purchaser when he raised the question. You and I have rare trucks, not only for having the original flooring, but lacking the strips. I have been going to shows and cruise-ins for 45 years and not seen another truck with the original wood bed in usable condition, period. | | |
