0 members (),
139
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 12 'Bolter | | 'Bolter Joined: May 2016 Posts: 12 | I see Optima batteries listed but would a ValuePower VP-26 Battery 525 CCA work for mt "54 3600? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes, probably at least a year?
Make sure you have clean cable connection (at both ends), and make sure you have 2 gauge or bigger battery cables/straps. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | I ran an Optima for eight years in my '38. It took a dump three years ago while we were on a VCCA tour & got replaced with a standard lead acid 6v. So far so good with it.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have 10+ year old 6v Optimas.
If you ever let one go dead, check the Optima website for the recharge technique (do not throw it away until you try that technique). | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | The trick to making any battery last is to give it some exercise. The absolute worst thing that can happen to it is to sit dormant. If a battery is discharged about 25% of its capacity and recharged frequently, and NOT allowed to bounce around excessively, it should last several years. Keep the connections clean and tight, discharge/recharge often, and don't let it go dead and stay that way, or allow it to sit idle for long periods. Jerry
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | you may want to check Tractor Supply for your 6 volt battery?? | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Something happened internally to mine Tim. It wouldn't respond at all to any attempt to recharge or jump start, totally dead.
| | | | | Joined: May 2016 Posts: 12 'Bolter | | 'Bolter Joined: May 2016 Posts: 12 | | | |
