Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (DaveV, jmoore, baldeagle, dt235sd, Lostbuthaulinass), 45 guests, and 1 robot.
Topics128,004
Posts1,055,246
Members48,418
#1212103 04/08/2017 12:37 AM
My truck did not have a gaskets for the headlights. Chevs of the 40's shows three. They all seem to do the same thing. https://www.chevsofthe40s.com/shop/...mp;sale=&showcase=&searchtype=FT
Looking for some comments on which you would use.
Dennis
40 Chevy 1/2 ton
Dennis, not sure looking at the advertisement but I used the ones with the wire in them when doing my panel. No problem, the biggest headache was the retaining clips. If you have your old retaining clips that is a good thing!!
Thanks Alvin. I'll probably do the same then. I don't have no stinkin' clips. I didn't realize I was missing anything until it is time to put it back together. Nothing inside the headlight bucket at all. Don't even know what it should look like. Which means no was to adjust other that moving the headlight bucket.
Dennis
40 Chevy 1/2 ton
Ex Hall Monitor
Ex Hall Monitor
I don't know how well this translates to a '40 truck but my '38 car had cork gaskets. I used window screen retaining cord to replace the cork. It's available every where and cheap.
I have always had little success in getting the rubber seals to sit where they are supposed to. Recently I noticed the ones with wires in them and mine don't have wires. I bought a pair and will install them shortly. I think the ones without the wires are useless.
1951 1 Ton Completed
I'm going with the wires too. Just ordered them.
Dennis
40 Chevy 1/2 ton
I do not believe my '46 has these either. What is their purpose? Do they go around the headlight inside the chrome trim ring? Can you see these from the outside? Does anyone have pics they can share of these installed? Thanks!
1946 Chevrolet 1/2-ton
More pix on Photobucket
Maybe THIS will answer your questions. I have attached 3 photos.
Harold
Harold
Mine had the wire with rubber ring. I don't think they will work well without the wire. I installed them but I don't think they do much to keep water out from behind the chrome ring.
Y
yar Offline
Y Offline
1/4" clothes line string was a perfect gasket for my '36 PU.
Ray
Thank you Harold46!
