0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#121225 07/15/2006 11:30 AM
What is the proper/easiest way to separate the hood? Do you drill out the rivets or is there a trick to removing the center pin? Thanks prior
Dan
#121226 07/15/2006 2:33 PM
The hood on my 46 came apart after liberal coatings of penetrating oil and opening and closing it while trying to slide one half of the hood with the other. It will eventually come apart. This by the way is with the hood off the truck completely and someone else helping me. I had to replace a few rivets as well and realign the hinges.Be careful as the hood warps very easy. Good luck, Bob T
#121227 07/15/2006 2:47 PM
I forgot to mention that I was talking about the center of the hood. On my 46 the hinge is actually stamped into each side of the hood and there are no rivets. One side of the hood slides into the other. The side doors on the hood are riveted hinges held together by a steel rod which can be pulled out with lots of penetrating oil. This is a Canadian built 46 so there might be a slight difference. Sorry if I confused you. Bob T.
#121228 07/15/2006 4:16 PM
No drilling required. The two halves should come apart. The two hinge halves are created by rolling the metal over the entire length of the hinge. Two two rolls slide together. There is no "pin" like on the doors.
I would lube the daylights out of it...they should just slide apart.
Hope this helps.
#121229 07/15/2006 6:52 PM
I made the mistake of drilling mine out. i wish I had known they came apart like that back then,.
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
#121230 07/15/2006 8:43 PM
Thanks all
Will PB today and attempt to slide apart maybe tomorrow. # 3 son has baseball this aft. Thanks again
Dan
#121231 07/19/2006 4:15 PM
Chev4t6,
How did the seperation go? I have a 46 truck and just removed the front support for the hood and a pin that runs the linght of the hood came out and it came apart.
Hope this helps
Ed
#121232 07/23/2006 4:40 PM
Well it took a week of PB and some cussing and a few beers but this AM hood slid apart without any
hassle. It was quite rusty and I believe that's what made it so hard. Off for a week at camp and back next week for a week of vacation working on the ole 4t6. Thanks for all the input
Dan
