2 members (festerhairball, fonz8261), 50 guests, and 5 robots.
Topics128,093
Posts1,056,046
Members48,433
#1211733 04/05/2017 2:17 PM
I have a 250 inline 6 installed in my 1959 Apache. It is about time for a new motor and I might have found a 292. From what I can tell, one of the motor mounts is closer to the front of the motor than the opposite side. Is there an easy way to make it work or would I have to change the mounts on my truck to make it work?
Thanks a lot,
Gene
Gene
1959 Apache
I have seem adapters but I don't remember where I saw them. It could have been home made. http://www.12bolt.com/store/p40/Steel_292_Motor_Mount_Adaptor.html
http://www.stevesnovasite.com/forums/showthread.php?t=75871
Here are a couple of links that may help.
Also check out this site!
http://www.chassisengineeringinc.com/
1946 1/2-Ton Chevy
Crusing in the Passing Lane
Just make a new mount for the mismatched one, well worth it.
Ed
Thanks guys. You have gave me the information that I needed. If I get a 290, I will probably get an adapter from 12 bolt.com. I would probably end up spending more than $50.00 by the time I fabricated my own.
Thanks again,
Gene
Gene
1959 Apache
