1 members (TrknGMC),
121
Mod | | | Forums66 Topics128,052 Posts1,055,774 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12109 08/13/2004 10:58 PM | Joined: Jul 2004 Posts: 18 Junior Member | | Junior Member Joined: Jul 2004 Posts: 18 | I would like to put radials on my 41 1/2 ton what is the best route to go if I want 15" rims, with a 6 bolt pattern. I don't want to change my hubs
41 1/2 ton
don't force it get a bigger hammer
#12110 08/13/2004 11:02 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | 15" rims that are stock are around...P/O had 15" rims on rear and 16" on front on my current 46. Rims look the same. I have located a full set of 15" but have not picked them up yet.
I had Aluminum 14" 6 bolts on my stock 41 hubs....
someone has what you want...stock or other. | | |
#12111 08/14/2004 12:57 AM | Joined: Jul 2004 Posts: 18 Junior Member | | Junior Member Joined: Jul 2004 Posts: 18 | Thanks 46. what I am looking for is rim from a later model car/truck that would take a tubeless radial tire.
41 1/2 ton
#12112 08/14/2004 2:57 AM | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Originally posted by 46 in progress: P/O had 15" rims on rear and 16" on front on my current 46. Funny, My '46 was set up with 15" on the front and 16" on the rear! I'm going with 16" all around. Tim
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | |
#12113 08/14/2004 3:22 AM | Joined: May 2004 Posts: 6 Member | | Member Joined: May 2004 Posts: 6 | Tim, My 46 came with 6 hole 15". I run P235 75R 15" blackwalls with radial tubes. About the right heigth, maybe a little wider than stock, but do not rub. Look pretty good, and at 50 mph I'll never wear them out...
Vos veritas liberabit.
#12114 08/14/2004 6:11 AM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | My 37 had the 15 inch artillery wheels on it when I got it and I am running radials and tubeless with no problems. | | |
#12115 08/14/2004 7:12 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | 15 inch wheels from 1970 on back had 6 holes & fit good. I ran a set on my 40 with 235x15 tubeless. Worked real good.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#12116 08/14/2004 9:25 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I found some "15 inch rims off a 57 half ton, that also used the spring clips for the hub caps, my 46 hub caps fit right on. I'm sure the same is true for pickup rims from 55 through about 59 or 60. | | |
