1 members (lumbersawyer), 84 guests, and 1 robot.
Topics128,055
Posts1,055,782
#12109 08/13/2004 10:58 PM
Junior Member
Junior Member
I would like to put radials on my 41 1/2 ton what is the best route to go if I want 15" rims, with a 6 bolt pattern. I don't want to change my hubs
41 1/2 ton
don't force it get a bigger hammer
#12110 08/13/2004 11:02 PM
15" rims that are stock are around...P/O had 15" rims on rear and 16" on front on my current 46. Rims look the same. I have located a full set of 15" but have not picked them up yet.
I had Aluminum 14" 6 bolts on my stock 41 hubs....
someone has what you want...stock or other.
#12111 08/14/2004 12:57 AM
Junior Member
Junior Member
Thanks 46. what I am looking for is rim from a later model car/truck that would take a tubeless radial tire.
41 1/2 ton
#12112 08/14/2004 2:57 AM
Quote
Funny,
My '46 was set up with 15" on the front and 16" on the rear! I'm going with 16" all around.
Tim
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
#12113 08/14/2004 3:22 AM
Tim, My 46 came with 6 hole 15". I run P235 75R 15" blackwalls with radial tubes. About the right heigth, maybe a little wider than stock, but do not rub. Look pretty good, and at 50 mph I'll never wear them out...
Vos veritas liberabit.
#12114 08/14/2004 6:11 AM
My 37 had the 15 inch artillery wheels on it when I got it and I am running radials and tubeless with no problems.
#12115 08/14/2004 7:12 PM
Riding in the Passing Lane
15 inch wheels from 1970 on back had 6 holes
& fit good. I ran a set on my 40 with 235x15
tubeless. Worked real good. smile
1972 Chevy c10 Cheyenne Super
#12116 08/14/2004 9:25 PM
I found some "15 inch rims off a 57 half ton, that also used the spring clips for the hub caps, my 46 hub caps fit right on. I'm sure the same is true for pickup rims from 55 through about 59 or 60.
1946 1/2-Ton Chevy
