0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12100 03/31/2005 5:19 AM | Joined: Mar 2005 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 85 | I'm considering dumping the old "boat anchor" cast iron 2 spd powerglide attached to my '57 235. Any ideas and/or advise?
thanks | | |
#12101 03/31/2005 6:37 AM | Joined: Dec 2003 Posts: 103 Member | | Member Joined: Dec 2003 Posts: 103 | I have a 56 Bel Air -- 235, I'm in the process of installing a 200R4 using a Buffalo Enterprises adaptor. Will keep you posted if interested. Also, similar thread in High Performance section. | | |
#12102 03/31/2005 12:40 PM | Joined: Feb 2005 Posts: 60 Member | | Member Joined: Feb 2005 Posts: 60 | Take a good look at the redrilled holes in the flywheel. Little close huh?Buffalo has tried to weld and extra plate to make it stronger than the other one but it breaks also. When you think your motor blew up with the knocking noise dont worry its only the flywheel breaking.It will happen around 500 miles all the way to 5000 miles. With the buffalo adapter at least you wont have to cut half the starter nose off or grind half the the rear bearing cap off. I did a lot of research on this one as i did not want the 5 speed i have now because of a bad knee. After seeing 6 broken flywheels that a young lad sent me i changed my mind. Not a good deal. | | |
#12103 03/31/2005 1:29 PM | Joined: Dec 2003 Posts: 103 Member | | Member Joined: Dec 2003 Posts: 103 | Buffalo's standard flywheel has a plate welded in the center of a V8 (I believe) flywheel and the new holes are drilled in it. Buffalo also offers -- for additional monies a completely new flywheel that doesn't have this modification. | | |
#12104 03/31/2005 2:24 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | twe56, i have tried to access the buffalo site and always comes up future site of and i can go no further. any suggestions. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#12105 03/31/2005 3:51 PM | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | doesn't langdons have an adapter plate for this purpose? seems i remember hearing other bolters talking about them.
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#12106 03/31/2005 4:25 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Here's a link to the tranny adapter. Trans adapter | | |
#12107 04/01/2005 1:37 PM | Joined: Mar 2005 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 85 | How much trouble would I be getting myself into if I decide to go from my 2 speed powerglide to a 3/4 on the tree? | | |
#12108 04/02/2005 2:13 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Buffalo doesn't have a web site. You can call him at 360-652-7684. Leave a message if he's not there. He will get back to you. | | |
