3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#12100 03/31/2005 5:19 AM
I'm considering dumping the old "boat anchor" cast iron 2 spd powerglide attached to my '57 235. Any ideas and/or advise?
thanks
I have a 56 Bel Air -- 235, I'm in the process of installing a 200R4 using a Buffalo Enterprises adaptor. Will keep you posted if interested. Also, similar thread in High Performance section.
#12102 03/31/2005 12:40 PM
DJ Offline
Take a good look at the redrilled holes in the flywheel. Little close huh?Buffalo has tried to weld and extra plate to make it stronger than the other one but it breaks also. When you think your motor blew up with the knocking noise dont worry its only the flywheel breaking.It will happen around 500 miles all the way to 5000 miles. With the buffalo adapter at least you wont have to cut half the starter nose off or grind half the the rear bearing cap off.
I did a lot of research on this one as i did not want the 5 speed i have now because of a bad knee.
After seeing 6 broken flywheels that a young lad sent me i changed my mind.
Not a good deal.
Buffalo's standard flywheel has a plate welded in the center of a V8 (I believe) flywheel and the new holes are drilled in it. Buffalo also offers -- for additional monies a completely new flywheel that doesn't have this modification.
twe56, i have tried to access the buffalo site and always comes up future site of and i can go no further. any suggestions. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
doesn't langdons have an adapter plate for this purpose? seems i remember hearing other bolters talking about them.
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
Here's a link to the tranny adapter.
Trans adapter
How much trouble would I be getting myself into if I decide to go from my 2 speed powerglide to a 3/4 on the tree?
Buffalo doesn't have a web site. You can call him at 360-652-7684. Leave a message if he's not there. He will get back to you.
