0 members (), 129 guests, and 1 robot.
Topics128,115
Posts1,056,292
Members48,439
#1210035 03/23/2017 8:30 PM
Moderated
Moderated
Hi, I am having trouble installing the weather stripping on my High cab push-out windshield. It won't stay in the channel at the rounded corners. Anyone have any suggestions? Thanks Ray
Ray,
Not sure if your window frame is made the same way as my 1941 version, but figured it is close. As you know from assembly, getting the rubber "barb" to catch on the frame is a test of patience. Are you certain you have pressed the seal in the frame sufficiently? I recall the corners were the most difficult. Have you used some dishwashing soap solution to help lube things up for assembly? Is your window frame rusty in that corner?
Lots more pictures
is your windshield gasket to long? You can cut some out if need be and glue the ends together with super glue.
Moderated by  ndkid275, Phak1
