| | | Forums66 Topics128,109 Posts1,056,258 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 1 Moderated | | Moderated Joined: Mar 2017 Posts: 1 | Hi, I am having trouble installing the weather stripping on my High cab push-out windshield. It won't stay in the channel at the rounded corners. Anyone have any suggestions? Thanks Ray | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Ray,
Not sure if your window frame is made the same way as my 1941 version, but figured it is close. As you know from assembly, getting the rubber "barb" to catch on the frame is a test of patience. Are you certain you have pressed the seal in the frame sufficiently? I recall the corners were the most difficult. Have you used some dishwashing soap solution to help lube things up for assembly? Is your window frame rusty in that corner? | | | | | Joined: Feb 2010 Posts: 86 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 86 | is your windshield gasket to long? You can cut some out if need be and glue the ends together with super glue. | | |
