3 members (Hotrod Lincoln, BC59, 1 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2016 Posts: 18 New Guy | | New Guy Joined: Sep 2016 Posts: 18 | I recently had the yoke on back of trans. replaced along with U-Joints, and Okie bearing, Now my 1953 Chevy is making a loud screeching noise that varies with the engine RPM. I have dressed the belts, that wasn't the prob. It seems to be coming from distributor, I lubed it and the screech is still there. At idle I can change the pitch of the screech by touching the distributor. HELP!
Thks: Keith 1953, 235, 3100 | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Remove the distributor and spin the shaft with a drill motor with the body of the distributor held in a vise. It sounds like you've got a galled mainshaft and/or top bushing. Jerry
| | | | | Joined: Sep 2016 Posts: 18 New Guy | | New Guy Joined: Sep 2016 Posts: 18 | Is there a way to lube that top bushing without removing the distributor. I tried adding lube and tightening the screw to the lube didnt work.
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Nope- - - -the bushing I'm referring to is right below the centrifugal advance weights, below the breaker plate. It takers a full disassembly of the distributor to inspect it, and the top of the shaft that contacts the bushing. A galled shaft requires replacing the distributor because there's no practical way to build up the shaft and get it smooth again. Jerry
| | | | | Joined: Sep 2016 Posts: 18 New Guy | | New Guy Joined: Sep 2016 Posts: 18 | ya know I was hoping something on this truck would be simple. Just experienced replacing yoke, U-Joints, Okie bearing, and seals now this. It seem like It is never ending.
Thx: Keith
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | It would probably be simpler to replace the distributor if the shaft is galled, but it only takes about 15 minutes to take it apart and confirm what the problem is. When I was running a shop I'd fire a mechanic who asked for help inspecting a distributor shaft, but that was 40-something years ago. Jerry
| | | | | Joined: Sep 2016 Posts: 18 New Guy | | New Guy Joined: Sep 2016 Posts: 18 | Ill tear into it this weekend. Let ya know..thx for the info. Keith
| | | | | Joined: Sep 2016 Posts: 18 New Guy | | New Guy Joined: Sep 2016 Posts: 18 | Well I removed the oiler and sprayed the distributor shaft with WD penetrating oil the Distrib runs smooth as silk, it would seem the screech is coming more from the flywheel area. The screech isn't constant more like the flywheel rubbing on something and causing noise the screech speeds up and slows down with the revs of the engine. I really need help here. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 |
| | | | | Joined: Sep 2016 Posts: 18 New Guy | | New Guy Joined: Sep 2016 Posts: 18 | I will chk tomorrow and see if maybe it could be that simple Thx Keith
