7 members (48jim1ton, 2-Ton, JW51, Jman, 32Fordpuchoptop, Jay R, Peggy M), 92 guests, and 4 robots.
Topics128,042
Posts1,055,601
#1210134 03/24/2017 6:56 PM
I recently had the yoke on back of trans. replaced along with U-Joints, and Okie bearing, Now my 1953 Chevy is making a loud screeching noise that varies with the engine RPM. I have dressed the belts, that wasn't the prob. It seems to be coming from distributor, I lubed it and the screech is still there. At idle I can change the pitch of the screech by touching the distributor. HELP!
Thks: Keith 1953, 235, 3100
kldob #1210137 03/24/2017 7:11 PM
Remove the distributor and spin the shaft with a drill motor with the body of the distributor held in a vise. It sounds like you've got a galled mainshaft and/or top bushing.
kldob #1210140 03/24/2017 7:30 PM
Is there a way to lube that top bushing without removing the distributor. I tried adding lube and tightening the screw to the lube didnt work.
kldob #1210141 03/24/2017 7:33 PM
Nope- - - -the bushing I'm referring to is right below the centrifugal advance weights, below the breaker plate. It takers a full disassembly of the distributor to inspect it, and the top of the shaft that contacts the bushing. A galled shaft requires replacing the distributor because there's no practical way to build up the shaft and get it smooth again.
kldob #1210143 03/24/2017 7:41 PM
ya know I was hoping something on this truck would be simple. Just experienced replacing yoke, U-Joints, Okie bearing, and seals now this. It seem like It is never ending.
Thx: Keith
kldob #1210148 03/24/2017 8:16 PM
It would probably be simpler to replace the distributor if the shaft is galled, but it only takes about 15 minutes to take it apart and confirm what the problem is. When I was running a shop I'd fire a mechanic who asked for help inspecting a distributor shaft, but that was 40-something years ago.
kldob #1210162 03/24/2017 10:03 PM
Ill tear into it this weekend. Let ya know..thx for the info.
Keith
kldob #1218419 05/23/2017 9:11 PM
Well I removed the oiler and sprayed the distributor shaft with WD penetrating oil the Distrib runs smooth as silk, it would seem the screech is coming more from the flywheel area. The screech isn't constant more like the flywheel rubbing on something and causing noise the screech speeds up and slows down with the revs of the engine. I really need help here.
kldob #1218426 05/23/2017 10:07 PM
Dented dust cover?🛠
kldob #1218429 05/23/2017 10:14 PM
I will chk tomorrow and see if maybe it could be that simple
Thx Keith
