Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (TexasJim50, Peggy M, Woodcmiami, farmallb, WICruiser, 66flea), 45 guests, and 4 robots.
Topics128,010
Posts1,055,299
Members48,419
#1209914 03/23/2017 1:04 AM
On 3 occasions when I turned on the headlights the engine has died. Each time it was at idle. The lights go out and the engine dies at the same time. The engine will start right after. I am tilted toward the P.O. wiring something wrong. Anyone come across this?
Jackie
I had that problem once and it turned out that the careless, jack leg, over-eating, low self esteemed, under-achieving shade tree mechanic failed to tighten the lead to the ammeter.
His only saving grace is that he listens to me when I talk to myself.
Carl
It's happened to me a couple times with a non-charging electrical system and/or a dead-dying battery.
Another quality post.
Real Trucks Rattle
Could also be dirty/loose battery cables.
Rick
1939 Chevrolet Stake Truck
Does the position of the dimmer switch make a difference? It sounds like a dead short somewhere downstream of the headlight switch that's dropping the system voltage enough to kill the ignition. Try turning the headlights on with the engine stopped, and see if they go dim or flicker on and off.
Well during my investigation I removed the light switch and found that the lights would flicker when tugging on the wire harness. I could also make the engine die with a little harder tug. I found the ammeter nut was VERY loose. I tightened it down and hopefully squashed 1 more gremlin.
Thanks All
Jackie
Thanks All
Jackie
Thank you Jackie. The the careless, jack leg, over-eating, low self esteemed, under-achieving shade tree mechanic who listens to me when I talk to myself feels much better about himself, knowing now that he is not alone. smile
Carl
