1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#1209604 03/21/2017 3:52 AM
I have a leak from the transmission just to the rear of the fill plug that looks something like a rivet Pic1 and a closer look Pic2. Anyone know what is the purpose of this rivet like piece? Any suggestions on a fix?
JackieC #1209607 03/21/2017 4:08 AM
Z
Z Offline
I believe this is the idler shaft lock pin which holds the idler shaft and idler gear in place...
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
JackieC #1209711 03/21/2017 9:32 PM
The leak is not bad at all and the transmission is working very well. Is there a fix for this or is it something I'll have to live with?
Jackie
JackieC #1209713 03/21/2017 9:53 PM
I'd suggest getting the case VERY clean and dry with something like brake cleaner or spray carb cleaner, then applying a layer of epoxy over the pin hole. Use an old toothbrush or something similar with the solvent to get every trace of oil off the case, or the epoxy won't stick.
I'd go with Jerry's suggestion as well. Could it be that it's leaking because someone beat the p1$$ out of it while installing? Sure looks beat up.
JackieC #1209717 03/21/2017 10:13 PM
It most definitely looks a bit rough. I've had the truck for a couple of years and the PO had it stored in a garage for 23+ years, so the beating occurred at least 2 decades ago!
JB Weld, or is there something better for this application?
Jackie
JackieC #1209762 03/22/2017 2:54 AM
I'd use plain old 10-minute epoxy, the stuff that comes in the 2-syringe container. If the place you're trying to patch is on a vertical surface, you might have to build a small dam with masking tape to keep it from running down the side of the transmission while it cures.
