| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Finally got around to looking at heat for AD Hooked up charger to leads and it spun really well. I let it run to make sure it seemed ok,then filled it with water to check for leaks(none,wow)
Afterwards I realized the charger was on 12V ,os I tested again on 6V . It ran,not as fast The motor did not get hot or smell when on 12V.
Will this work correctly,or should I use 6V ?? | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | Is it a 6V or a 12V motor?
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | My recent experience the 6 volt blower motor runs way too fast on 12v.
There are couple of other post with replacement motors suppliers in 6 and 12 volts.
I decided to run my 6 volt on 12 volts using a ballast resistor to reduce the voltage. The resistor sitting in the air stream. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | I have the ballast resistor, but I also have a rheostat switch I could use to adjust speed.
Not sure what voltage motor actually is. | | |
