5 members (rfs56trk, Otto Skorzeny, FAST55, 216wny, Gdads51), 86 guests, and 1 robot.
Topics128,038
Posts1,055,585
#1209387 03/19/2017 9:58 PM
So I'm 7 years deep into a 58 Apache restoration and I've managed to get around to starting the rebuilt 235.
Fuel is pouring out the butterfly shaft bushing, and quite honestly the carb looks like complete hell.
I need a new carb for this old girl. The old Rochester has put in many decades of service, and its time to move on.
I see Carter makes a carb with an ever-appealing auto choke feature.
What do you guys think? Is this a wise move? what do you kings of carburation recommend?
Thanks fellas!
1958 Chevy Apache Fleetside/235/3 sp
Pictures at http://www.facebook.com/album.php?aid=317454&id=855355703&l=0a0f773195
Skidmarks #1209388 03/19/2017 10:02 PM
What model Carter?
What size engine was it used on?
Skidmarks #1209391 03/19/2017 10:08 PM
Engine is a 58 235 bored 40 over.
Don't know which model Carter, what do you think would work? Ive seen a few listed that work on the 235 but I don't have a particular in mind.
Skidmarks #1209395 03/19/2017 10:50 PM
The Carter YF 2100S was manufactured for the 55-59 235's. It was specifically made by Carter as an aftermarket replacement for the stock Rochester B. It bolts right on and the linkage is an exact match. It is a manual choke. If you start to look for a Carter YF, be sure that you hunt specifically for a 2100S model. There are many different model YF's, and you'll want to find the one made for your '58 235.
Matt
Skidmarks #1209396 03/19/2017 10:54 PM
Thanks, Matt
