1 members (Eileen), 271 guests, and 2 robots.
Topics128,101
Posts1,056,181
Members48,436
#1208939 03/17/2017 12:14 AM
I'm rebuilding a 55 GMC cab and converting it to become a Chev cab for my 58 fleetside. My original cab was badly rusted out. It has gone to the scrap yard. The 55 GMC firewall was perforated with lots of extra holes. I've relocated the bottom hood hinge bolt hole. I have pictures of the old firewall from the engine side, but nothing on the inside. By process of elimination, I've figured out which holes I need, which ones I need to add (horn relay), and which ones I can plug. I've checked my factory assembly manual, but it does NOT include a separate fuse panel.
So where is the fuse panel mounted for a 1958 Chevrolet?
When God gives any man wealth and possessions, and enables him to enjoy them, to accept his lot and be happy in his work�this is a gift of God. He seldom reflects on the days of his life, because God keeps him occupied with gladness of heart. Ecclesiastes 5:19-20
John D #1208941 03/17/2017 12:29 AM
the 55-59 trucks only had a fuse panel if a number of accessory items were installed .... it would be located on the inside of the firewall above the clutch pedal as seen here - there's a dotted cutout in the cardboard where it's tab screws on [tab seen behind capacitor in foto]
Thanks Bill.
I don't have the cardboard firewall insulation panel yet.
I can find the spot welded cable tab as per your picture for reference.
In your picture, it would appear that the mounting tab screws would come through the firewall just above the top outside voltage regulator bolt hole, just below the horn relay. Does that make sense ?
I found one hole, and the other hole is on the edge of a 3/4" hole. I'll have to file the big hole first, then drill the second tab hole.
don't recall exactly the mounting, but maybe weld nuts on the engine side of the firewall - the mount holes in the tab are only about an inch apart .... don't think position is critical unless you're picky about originality, which will be tough at any rate with the GMC-Chev conversion smile
