1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 69 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 69 | I'm rebuilding a 55 GMC cab and converting it to become a Chev cab for my 58 fleetside. My original cab was badly rusted out. It has gone to the scrap yard. The 55 GMC firewall was perforated with lots of extra holes. I've relocated the bottom hood hinge bolt hole. I have pictures of the old firewall from the engine side, but nothing on the inside. By process of elimination, I've figured out which holes I need, which ones I need to add (horn relay), and which ones I can plug. I've checked my factory assembly manual, but it does NOT include a separate fuse panel.
So where is the fuse panel mounted for a 1958 Chevrolet?
When God gives any man wealth and possessions, and enables him to enjoy them, to accept his lot and be happy in his work�this is a gift of God. He seldom reflects on the days of his life, because God keeps him occupied with gladness of heart. Ecclesiastes 5:19-20 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 55-59 trucks only had a fuse panel if a number of accessory items were installed .... it would be located on the inside of the firewall above the clutch pedal as seen here - there's a dotted cutout in the cardboard where it's tab screws on [tab seen behind capacitor in foto] Bill | | | | | Joined: Oct 2009 Posts: 69 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 69 | Thanks Bill. I don't have the cardboard firewall insulation panel yet. I can find the spot welded cable tab as per your picture for reference.
In your picture, it would appear that the mounting tab screws would come through the firewall just above the top outside voltage regulator bolt hole, just below the horn relay. Does that make sense ?
I found one hole, and the other hole is on the edge of a 3/4" hole. I'll have to file the big hole first, then drill the second tab hole.
When God gives any man wealth and possessions, and enables him to enjoy them, to accept his lot and be happy in his work�this is a gift of God. He seldom reflects on the days of his life, because God keeps him occupied with gladness of heart. Ecclesiastes 5:19-20 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | don't recall exactly the mounting, but maybe weld nuts on the engine side of the firewall - the mount holes in the tab are only about an inch apart .... don't think position is critical unless you're picky about originality, which will be tough at any rate with the GMC-Chev conversion  Bill | | |
