5 members (rfs56trk, WingWright, Jon G, Rusted Nut, Woodcmiami), 117 guests, and 1 robot.
Topics128,109
Posts1,056,260
Members48,439
I took the gauge cluster out of my 58 viking, and found my speedo gearbox wasn't ever hooked up. That explains the hissing. I have no idea how to get parts for it, as the bellows are cracked and I need to disassemble it to clean and regrease it. Any ideas for what I have? I can only ID it as a Stewart Warner, pat. 1984082.
https://drive.google.com/open?id=0B6Aw4aYru4MTaFluVE9la1hHUU0
The Pics are GED0194 and GED0195
The gear box looks exactly like the earlier units used in the 40's and 50's. Instead of a mechanical link to the 2 speed manual lever under the dash, they put a diaphragm on it to shift the gears.
So mechanically the same, should be plenty of info on the older units.
Pretty straight forward, disassemble, clean reassemble, seal and fill.
The diaphragm is the unique part for the older units. Wouldn't be supprised if parts weren't available for 1960's trucks that used the same thing.
The 2-speed speedometer adaptor is a non-servicable unit, parts were never made available to the public.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Big Bolt Forum Moderator
is this what you are looking for?
http://www.ebay.com/itm/161708570680?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Mike
I stand corrected, the diaphram (Control) is available and that's a good number! Thanks Mike!
I sure hope those NOS diaphrams are still soft and plyable for the big money they're asking, they could be hard as a rock eeeek
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I found one a few months ago, not NOS but great shape, I think I paid about 30$. My dad also retro-fitted a vacuum advance diaphragm onto one for me.
As an FYI, you can pull the gearboxes apart and clean/lube them.
Mike
I was about to suggest using a vacuum advance unit. It seems that with a little creative bracket adapting that would be an inexpensive alternative to a NOS part that might be dried out and unreliable. I have used thin rubber gasket material to make vacuum and air diaphragms, and even rebuild obsolete outboard motor fuel pumps.
Hello
I was into my parts stash the other day and found
a 55.2-59 speedometer housing with the gearbox attached
to the speedometer cable input. Is this what you need?
It is old and original, but has been out of the weather for 20 some years.
respectfully , 59shortfleet
cool I made one from a vacuum advance I had on the bench-took a little while to make it fit and work,but it seems to work fine so far. And it was FREE!!! thumbs_up
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
