0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 114 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 114 | I took the gauge cluster out of my 58 viking, and found my speedo gearbox wasn't ever hooked up. That explains the hissing. I have no idea how to get parts for it, as the bellows are cracked and I need to disassemble it to clean and regrease it. Any ideas for what I have? I can only ID it as a Stewart Warner, pat. 1984082. https://drive.google.com/open?id=0B6Aw4aYru4MTaFluVE9la1hHUU0The Pics are GED0194 and GED0195 | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The gear box looks exactly like the earlier units used in the 40's and 50's. Instead of a mechanical link to the 2 speed manual lever under the dash, they put a diaphragm on it to shift the gears. So mechanically the same, should be plenty of info on the older units. Pretty straight forward, disassemble, clean reassemble, seal and fill. The diaphragm is the unique part for the older units. Wouldn't be supprised if parts weren't available for 1960's trucks that used the same thing. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The 2-speed speedometer adaptor is a non-servicable unit, parts were never made available to the public. Mike B  | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | is this what you are looking for? http://www.ebay.com/itm/161708570680?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I stand corrected, the diaphram (Control) is available and that's a good number! Thanks Mike! I sure hope those NOS diaphrams are still soft and plyable for the big money they're asking, they could be hard as a rock Mike B  | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I found one a few months ago, not NOS but great shape, I think I paid about 30$. My dad also retro-fitted a vacuum advance diaphragm onto one for me.
As an FYI, you can pull the gearboxes apart and clean/lube them. | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | I was about to suggest using a vacuum advance unit. It seems that with a little creative bracket adapting that would be an inexpensive alternative to a NOS part that might be dried out and unreliable. I have used thin rubber gasket material to make vacuum and air diaphragms, and even rebuild obsolete outboard motor fuel pumps. Jerry
| | | | | Joined: Aug 2015 Posts: 48 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 48 | Hello
I was into my parts stash the other day and found a 55.2-59 speedometer housing with the gearbox attached to the speedometer cable input. Is this what you need? It is old and original, but has been out of the weather for 20 some years.
respectfully , 59shortfleet | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 |  I made one from a vacuum advance I had on the bench-took a little while to make it fit and work,but it seems to work fine so far. And it was FREE!!! Speed | | |
