3 members (Hotrod Lincoln, BC59, 1 invisible), 134 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#1208020 03/11/2017 7:17 PM
what kind of fasteners are use to hold my 55.1 sun visor in place. I want to remove to install a head liner but don't know what to use. there are three pointed studs.do they twist out? screw out? drill out? thank you , brian
1955 First series 3600 3/4-ton
"A Great Starting Point"
Follow the story and pix in the DITY Gallery
Do you have pictures? My 52, and all I've seen right up o my son's 81 have three philips screws.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
66flea #1208144 03/12/2017 12:38 PM
I have a couple NOS RH sun visors for AD's they are Phillips screws.
https://www.flickr.com/photos/advance-design_parts_co/12258396864/in/album-72157631868452754/
https://www.flickr.com/photos/advance-design_parts_co/24630422886/in/album-72157631868452754/
As you can see on the install instructions for the GMC visor (on a box flap), it calls out the self-tapping screws.
66flea #1208145 03/12/2017 12:45 PM
Those three pointed-studs might be helpful if you have a head liner that does not have holes in it for the visor/visors attachment screws.
You can position the head liner into position and press it upwards towards the pins - remove the headliner, and then drill the holes into the headliner, and then locate/cut/drill the hole you have to make for the visor spring/mechanism.
https://pix.sfly.com/Qq2YCD pictures of fasteners
my teenage daughter just set up some pictures. lets add computers to the list of things I don't know anything about (right under old Chevrolet trucks)
NIce photos by your daughter:
photo 1
photo 2
Are the "spring nuts" holding the pins in place?
If yes, can you pry off the "nuts?
They are not original.
what are spring nuts? i'm going out side to see if i'm missing something .I will see if I can get a picture of the back
If they are not spring nuts, maybe someone else will try to discern/guess what they are.
You might have to break/cut-off the "posts/pegs", if you cannot turn/pry-off the "nuts"?
I put the phone (camera) back there and discovered that they're just weird screws. then I used a vice grip to remove them. i'll probably use them as you suggested to locate the new holes in the new headliner. thanks to all that replied, brian. p.s. now that I have photo sharing(thanks to my daughter) i'll get some pictures up. it's been over five years and I have a ton of pictures
Moderated by  ndkid275, Phak1
